puzzling sound
When I turn on the ignition, there is a sound behind the dash (I would guess centre part) which is likeradio static/crackling. No it's not the radio. It stops when I remove fuse 18, which is listed by Chilton as warning indicator lamps, throttle solenoid positioner (?), low fuel module, dual timer buzzer, tachometer, engine idle track relay, fluids module/display. The car seems to be working normally, so I'm not worried, should I be?
Can anyone guess what this sound is, or suggest some tests for me to do to find out?
breaking
Oct 2, 2015 01:27 PM
KingRando
Oct 2, 2015 08:06 AM
