backfire through carb new heads
well after i finally get the bolt i need and put the car back together. it backfires through the carb like crazy.... so i thought the intake valves were to tight and not closing but it still did it.
RE: backfire through carb
have you done a compression test???? low compression on more than one cylinder will cause incomplete cumbustion and cause backfires out the tail pipe.....my friend has a 77 ford that does that right now!! but I know you say out the carb so do a compression test!! a burnt intake valve can cause the same thing which will show up on a compression test and if such is the case you may have a slightly rough idle too???
it has a burnt exhaust valve in cylinder 8 all the other valves are fine for the time being. it holds a solid 120 in all the other cylinders except 8 which has 30lbs of compression
