Where to bolt up to on motor w/ hoist.
RE: Where to bolt up to on motor w/ hoist.
Well, I dont have any hooks or brackets...completely custom setup. Below is what I have to work with on the front driver/side. I was think about just bolting up to one of the bell housing bolts and maybe to the alternator bracket. Also, maybe wrapping the chain around #4 & 5 exhaust mani pipes. If you guys have any other suggestions, let me know.
How about using 4 good bolts, one in each head, run them through two lengths of sturdy chain(saw a guy using chain no bigger than swag) and run a hook through where the two chains meetor use aload leveler(best)
your over stressing...
throw a bolt in the front right and back left in the heads where header bolts go... and pick it up... ive done it numerous times w. iron heads(not aluminum tho, but id do it w. them too) or use the accesory holes in the front/back of the heads w. a bolt
yea you have a clear shot onto the fron of the heads at least so id go for front and back. thats how i plan on it when im ready. or if your really worried they make a plate that bolts to the lower intake (helps spread load) used for pulling engines.
