stock ratio rockers?
Old 03-13-2005, 07:56 PM
Tims 88GT
Tims 88GT's Avatar
Default stock ratio rockers?
hey guys what ratio are stock rockers?
Tims 88GT is offline
Old 03-13-2005, 07:58 PM
Aixtreme89
Aixtreme89's Avatar
Default RE: stock ratio rockers?
1.6 to 1
Aixtreme89 is offline
Tims 88GT
Tims 88GT's Avatar
also, what would my lift be with 1.7 ratio rockers with a .522 lift cam?
Old 03-14-2005, 12:17 AM
91hatchgt
91hatchgt's Avatar
It will give your car .030 more lift.. so from .522 to .552
91hatchgt is offline
Old 03-14-2005, 12:19 AM
Aixtreme89
Aixtreme89's Avatar
Im pretty sure you wont be able to use a cam that big with stock pistons. But I may be wrong.
Old 03-14-2005, 12:22 AM
Magiarn71
Magiarn71's Avatar
ORIGINAL: 91hatchgt
How did you come to that?
Magiarn71 is offline
Old 03-14-2005, 12:46 AM
Tims 88GT
Tims 88GT's Avatar
i have the .522 now, you can go as big as the ford x cam which i think is like.546 but im not shure, so if i got magnum roller rockers in a 1.65 ratio, would i be ok still? also is their a web site that i can go to that will tell me how to do some of this math myself?
Old 03-14-2005, 01:46 AM
91hatchgt
91hatchgt's Avatar
ORIGINAL: Magiarn71
ORIGINAL: 91hatchgt
I will explaine how they work. The only reason the ratio changes is becaust the pushrod pocket is located more towards the stud, or where it is mounted, this increases the ratio to 1.7 which gives an increase in both lift and duration. Lift increases are .030 so add that to his now .522, and you get .552
Old 03-14-2005, 01:59 AM
Tims 88GT
Tims 88GT's Avatar
so if i had a 1.65 rocker that would make lift a .537?
Old 03-14-2005, 02:04 AM
91hatchgt
91hatchgt's Avatar
There is no such thing as a 16.5 Ratio Rocker that I know of.
Quick Reply: stock ratio rockers?
