Help
Old Dec 13, 2007 | 05:26 PM
RedMachAndOrangeFox's Avatar
RedMachAndOrangeFox
Default Help
i need help finding out where this pipe bolts to it is hainging low and getting moved around making noise, its from the smog pump to the exhaust here are some pics
it is hanging low and in this last pic it is the second pipe you see, the lower one and there is a flange with a bolt hole
Old Dec 13, 2007 | 05:53 PM
dimebag's Avatar
dimebag
Default RE: Help
should go on a header bolt i believe
Old Dec 13, 2007 | 06:26 PM
chevykilla93's Avatar
chevykilla93
Default RE: Help
Bolts to the header and mine was originally welded to the hpipe instead of the tube and clamps so it use to be alot more rigid. Just try playing with it, bent it up out the way a little more if its hanging too low.
Old Dec 13, 2007 | 06:43 PM
splash21's Avatar
splash21
Default RE: Help
or if you dont have inspections, remove your smog system haha
