car wont start???
Old 12-17-2007, 08:06 PM
andywear87
andywear87's Avatar
Default car wont start???
ok this morning i go out to my car and it starts but dies cause it is cold and when i try to restart it it just clicks in the silonoid so i knew it needed a starter anyways cause it doesnt like to start when its hot so i buy a new starter and selonoid and it still clicks at the silonoid what could it be????
andywear87 is offline
Old 12-17-2007, 08:07 PM
92cobra
92cobra's Avatar
Default RE: car wont start???
it could be the battery bud. try taking the terminals off the battery and then putting them back on to make sure they have good contact. Also its a good call to get the battery tested, its free and will letcha know whats up.
92cobra is offline
Old 12-17-2007, 08:15 PM
splash21
splash21's Avatar
or the solenoid could be bad.
splash21 is offline
Old 12-17-2007, 08:19 PM
andywear87
andywear87's Avatar
the solenoid again? i am pretty sure battery is good i will check it again though anyh other ideas?
Old 12-17-2007, 08:51 PM
fourfivefour
fourfivefour's Avatar
As suggested above, check your battery and connections.
If you have cheap replacement battery terminal ends make sure the cable is clean and tight.
Wiggle everything and look for loose connections, repair as necessary.
fourfivefour is offline
djbigskrilla
09-20-2022 01:04 AM
drumhedd2005
08-13-2015 09:59 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
89blueslug
08-10-2015 07:20 AM
Quick Reply: car wont start???
