Fuel Pump decision
I was thinking Holley Blue with 3/8 lines? those of you with carb'ed stangs take a loong at my sig and tell me if it will be good to go. the car is comming together well and that is the next step.
patience!! most at this time a day are at work..me on the other hand I'm on vaccation but the holley blue will be fine for your mods..I'm soon to install when it gets here a 347 also with afr 185's and my cam is a xe282 hr 565/574..and I'll be using a 100 shot on top of that so the holley blue will serve you well..it's a little on the noisy side but if your car is too, than it won't matter
I currently have a Holley Red in my '65 fastback. Granted, I've only used it for 205 miles and am now yanking it for an EFI swap, but it is certainly not the quietest pump in the world. As mentioned, you won't here it over the motor if it is only the louder side (I have Magnaflow exhaust), but at idle or standing behind the vehicle, you'll definitely hear it.
Good luck!
Jeff
Good luck!
Jeff
mrappe
Sep 26, 2015 10:16 AM
