Need Tuning Help
Hi everyone....I am new to the site so please be patient. OK I have a 89 Mustang LX 5.5 Conv. That is modified. her is a list of the mods.
Engine Information[/b]
Ford Motorsport M-6007-XE3 bored .010 (306) with Motorsport forged pistons . It has the aluminum GT40 heads (M-6049-X303) with the GT40 valve train.
1.6 Ford Motorsport Roller Rocker arms
GT40X302 aluminum heads
Ford Motorsport "E" Cam
Trickflow intake
BBK adjustablefuel pressure regulator
Vortech S-Trim V1 Supercharger
BBK 77mm Throttle body
BBK 77mm EGR plate[/ul]
Other Information[/b][/align]
BorlaCat Backexhaust
BBK equal length shorty headers
Bassani Stainless Steel X pipe with cats.
Centerforce Dual Friction clutch (6,000 miles)
Pro-M Bullet 75mm mass air meter
Afco Radiator
Eaton electric fan
25lb Fuel injectors
MSD 6 BTM boost timing retard unit
MSD 6AL Ignition
MSD coil
155 lph in tank fuel pump
Vortech T Rex external fuel pump
Will also include a Ford Rotunda and complete manual
Ford Motorsport offroad springs.Lowers the car about 3/4" and maintains a pretty decent ride quality.
Ford Motorsport "hurst" shifter.
Ford Motorsport 140mph speedometer[/ul][/ul]
Now the problem is I cannot get it tuned right. When I get on it it pings terrible. Exhaust is very stinky if you know what I mean really rich. Any input would be great. Does this look like a good setup? Is ther anything you would change? Thanks for any advice.
Howard
Trickflow intake
Afco Radiator
Eaton electric fan
25lb Fuel injectors
MSD 6AL Ignition
MSD coil
Howard
http://www.smokemup.com/utils/dynosearch.php
check out that site...
also Pro50sc is from MD, im sure he will chime in and tell you where he got his dyno tune done... there are other members from their too
Pro50 knows all, especailly when it comes to chargers, i think he's been running his for 4 years or more with no major issues, def get a tune done on a dyno bya good shop and you should be in good shape, street tuning can be tough (and if you're like my dumbest friend pop a motor while doing so)
"and a stand alone fuel management system, damn, not a bad way to spend 10 grand" lol, anyways, nice setup you have there, im envious of the build minus the cam =P.
on to the issue, what is your timing set at? have you thought about getting a professional tune done? have you thought about using a pms or getting a professional tune. Also what size injectors are you using?
goodluck getting it solved and nice build. I also recommend you upgrade your fuel pump to atleast a 225lph.
