1994 Gt conv aode suggestions
what do u guys think, should i get
1.ProCharger HO P600B Supercharger Kit w/Intercooler for 94-95(9psi)
2.Powerdyne Supercharger Kit for 94-95 (6 psi/satin)
3.Or TRICKFLOW KITS 5.0L EFI -FORD -EFI ENGINE KIT
350 HP/370 TORQUE
KIT INCLUDES:ASSEMBLED TRICKFLOW TWISTED WEDGE ALUMINUM HEADS, MATCHED HYDRAULIC ROLLER CAM, ROLLER ROCKERS, GASKET KIT, PUSHRODS, DOUBLE ROLLER TIMING CHAIN, AND SILVER VALVE COVERS.
LIFTERS NOT INCLUDED
I want something safe for my car and reliable, but i want it to be fast also. the procharger itslef cost 3600, while the other 2 cost around 2200. i wanted to know which do u guys is worth it. i also wanted to know would the Trick flow efi help build up my engineso it can suppport superchargers better or wat cuz if i go wit it i juss mite put a supercharger in a couple of years. It would also b nice if u guys can tell me wat u guys guess i would run wit these setup's( I know there a million different things that can go rong,driver,tires,gears, watever) I juss wanted a guesstimate
350 HP/370 TORQUE
RE: 1994 Gt conv aode suggestions
i like the trick flow setup. with good tires, gears, and a decent driver that should put you in the mid to high 12's. note that those hp numbers are flywheel hp, not rwhp. you will also need to upgrade your injectors, and fuel pump. get an aftermarket fpr too.
i just answered this question in the other thredhttps://mustangforums.com/m_432802/tm.htm
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
