70mm MAF $5.00
RE: 70mm MAF Technical Conversion
ORIGINAL: my77stang
doesnt the sensor thats in the housing need to be calibrated for the size of the housing that its in? if not, then this is a great junkyard find
Experience from Idle to 100 MPH TODAY
1. Smooth idle.
2. Sensitive Throttle Response, with more power from idle to redline in the RPM range.
3. No idle OR MISFIRING issues at all.
4.ECM learned it and adjusted in 45 seconds at Idle.
5. Removed the air intake silencer plate and got a misfire, at idle, so dont remove the plate.
1. Smooth idle.
ORIGINAL: 50Stocker
are you talking about the air silencer on the inner fender? Or did you grind/take something else out?
screws
