EFI TO CARB
EFI TO CARB
ive been looking around on some ideas as to switch efi to carb setup on my 5.0. so far i see alot of guys are going from carb to efi!? whats goin on!? honestly is it worth the hastle? im gonna be tearing the car apart shortly and eventually boostinit. but idont know what all come with carbing a efi computer'd car?!? if anyone has a step by step that would be great?!! thanks guys
RE: EFI TO CARB
there is a lot of info on this topic using the search function but to convert there is a lot to do if you want it to look right.....the benifit to carb will be quick fast tunability by yourself if you know carbs..and you won't have the dreaded idle surge accompanied with an efi car........
RE: EFI TO CARB
ORIGINAL: djcondo
has anyone ever done this, because i was going to do it too. Is there a big difference in gas millage? if anyone knows let me know
RE: EFI TO CARB
i have a 1991 stang that i put a worked 351w carbed. and i love it sounds go with the carb. Took out my engine harness moves any wires i need in to the inner fender and i am running a autometer gauge cluster that i had to wire up, and i had to run a 3 foot wire to the fuel pump relay under the seat cause the efi harness has the wiring for the fuel pump relay. wasn't that bad just takes some time.
RE: EFI TO CARB
even you got dumpy milage, to me it would be worth it. no sensors or bull****, injectors, nothing! you buy a nice single plane intake and like a road or street demon youd be good. Im planning on doing a sheet metal intake and running an Avanti carb, if any of you are familiar with those, very nic carb. youll pick up a few horse with a good fuel system, ect. electric watr pumps are nice, single wire alternators, and your gauges. im already runnin everything mechanical except speedo, im planning on tearing th stock gauges out make a carbon fiber panel or whatever, and shove a 5" speedo and tach be done with it. i got some pretty good info doing this from a fellow forum member and its sounds scary but also sounds fun because it would be a project of its own in a project!! as tradecki stated it takes time! [sm=exactly.gif]
bradleyb
11-27-2015 07:50 PM
Daddys Girls GTs
09-14-2015 08:46 PM
jaiidutch
09-14-2015 10:29 AM
