Where is a/c reservoir?
Old Mar 17, 2005 | 12:27 AM
Demon_Mustang's Avatar
Demon_Mustang
Default Where is a/c reservoir?
Hey guys, I want to check if I am in need of more a/c gas, where is the reservoir so I can check this? Also, anyone know what type of gas my Mustang uses? (1992)
Old Mar 17, 2005 | 12:50 AM
89stanglx's Avatar
89stanglx
Default RE: Where is a/c reservoir?
Referigerant charge needs to be checked with referigerant gauges, depending on the referigerant r-12/r-134a use different pressures.
Old Mar 17, 2005 | 01:35 AM
86HOGT's Avatar
86HOGT
Wow....
Anyway,
It's illegal to just top off any A/C system in the US. If a shop finds that it's low, they are required by law to fix the system before recharging it, and they don't have to give you any of the refridgerant back they take out to test it after you decide it's too much to fix. If you're not certified nor have the equipment to service A/C systems, you can't work on them...legally.
Old Mar 17, 2005 | 02:59 AM
Demon_Mustang
Yah, and legally I can't be driving on the road with the off-road h-pipe that I have installed.
So... anyone know where the reservoir is? Some cars have a small glass port and you can tell if it's low if you run the car and turn on the a/c and you see it bubbling. I wonder if it's the same with the Mustang...
Old Mar 17, 2005 | 10:06 AM
mustang8719's Avatar
mustang8719
There is no sight glass that I am aware of.If the system is R12 you have to be certified to work on it.If it is 134a you can do it all your self and it is not illegal.You can purchase 134a in the auto parts store for pretty cheap.
Since summer is coming alot of shops will be running specials here in FLA. a/c performance test for free.Most of the time it is free with an oil change.
Old Mar 17, 2005 | 10:36 AM
86HOGT's Avatar
86HOGT
Just because you can purchase it, DOESN'T mean you can still legally work on it and top it off, simple as that.
Old Mar 17, 2005 | 11:13 AM
titan aresta's Avatar
titan aresta
The reservoir tank is on the passanger side of the engine compartment, near the hood hinge. If you still can't find it, just fallow the upper AC line from the compressor.
There is no window (or anything of the kind) on the reservoir tank though.
Old Mar 17, 2005 | 01:28 PM
86HOGT's Avatar
86HOGT
That's an accumulator, not a reservior tank. The only way to check how much you have in the system is to hook up an A/C machine and do a recovery.
Old Mar 17, 2005 | 03:48 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: 86HOGT
You have to have R-12 compatible gauges. In order to buy them or the gas you have to be ASE A/C certified and have some other EPA approved certification. I used to work in the auto parts industry when they changed the laws. It's not worth the federal fine/jail time if you're found with that stuff. Controled substance = federal offense.
Old Mar 17, 2005 | 04:31 PM
fats429's Avatar
fats429
If the car has not bin updated it is a R-12 sytem , to convert to 134-A it is olny a quick oil change and a new accumulator / dryer (thats the thing next to the hood hinge and heater core) . The sight glass I think is olny on the old mopars I think but not on the Fords . never hedre of the reservoir do you mean the condencer it's in front of the rad .
if you do this job your self you will havto go 134-A . the kit is fairly cheep . the accumulator / dryer should have a sticker on it how mutch feraon you will need to fill the system . NOTE once you oppen the lines you need a new accumulator / dryer , you may also need a new o-ring kit if the freaon is leeking out it is prolbely from a bad o-ring . the tool to check the system is called a manafold gauge . it ha 3 hoses and 2 round gauges at the top. the lines from the tool hook up to frig lines on the car by scradder valves , thare is a high side and low side and the other line on the tool hooks up to the bottle . not a hard job just read the gauge
This job cost at a shop what you are going to spend on the frig, tools , material , and the book with the specks . S if you don't plan on doing at least 3 a year just have it done at a shop it will end up coasting the same
134-A is 100% OTC LEGAL , if your car has R-12 you hafto get it recoverd by a shop with the right equment , the more than likely wont charg you to just recover thats what I always do ( wink- wink)
