any reason i shouldn get solid motor+tran mounts a
RE: any reason i shouldn get solid motor+tran mounts a
from what I always heard solid mounts are for track cars most of the time. will it hurt anything, prolly not, but will you hate the ride, probably. get some poly ones
ORIGINAL: dimebag
i thought about it.... but i wouldnt do it...
and aperantly(aka from what i HEAR)... solid motor+solid trans mounts =cracked bellhousing
I personally went with heavy duty stock mounts, no vibration and a lil stiffer than oem. I think they're actually considered convertible motor mounts.
i went and bout the energy mounts because my worn out stock mounts had caused the tail shaft housing to crack from one side around to the other... there was alot of burnt up tranny fluid that day
I run solid motor mounts with poly trans mounts. Unless your engine balance isspot on, i would not go with the solid. My car has 0 vibration with the solid mounts, the only thing you feel is the rumble of the 600+ lift cam. If you do decide to go with solids, do not get solids for the tranny.
I tried a solid tranny mountwhen I noticed my rubber mount was shot but I switched it back to the rubber mount soon after.It made thewhole car vibrate, and there was always a buzzing sound. It was annoying with the shifter vibrating in yourhand too. I would never install this on a street car again.
i wouldnt install a white hood on a black street car either[8D]
lol jk... in all seriousness what size cowl is that, and where can one purchase such a hood? any other shots of it?>
