Is a camshaft really worth it?
im just torn, and im not sure if its really worth buying and installing a cam in my car. will it really benefit my setup? im running a stock ho cam with 1.7 rr. what kind of horsepower have you guys seen on an otherwise stock cobra 302 (milled .010, 3 angle valve job is all i have)? other mods in my sig.
RE: Is a camshaft really worth it?
The Steeda #19 is a good choice because even with the 1.7 rockers you're still only running .510 lift, i'm happy with my combo. GT40 heads are definitely good enough to benefit from a cam unlike the E7s.
thanks guys, you talked me into it. i just wasnt sure if it was worth it. i was just concerned that i wouldnt gain much, and then not pass cali smog and idle like crap. couple more questions:
do the sn95 ecu's like more lift or more duration?
what do the 1.7's add to the overall lift of a cam?
how much lift/duration would be overkill for my combo?
thanks again!
thanks again!
ORIGINAL: tooslow5.0
thanks again!
thanks again!
ORIGINAL: Joel5.0
The 1.7 rockers = 6.25% more lift than the 1.6 rockers, and it doesn't affect emissions.
thanks again!
thanks again!
