slight problem with heater
Old Dec 29, 2007 | 03:42 PM
1mean5.0's Avatar
1mean5.0
Default slight problem with heater
If I have my heat on high fan setting it blows steady but if I put it on the 1st 2nd or 3rd setting it blows out pretty hard then it kicks down and then kicks back up and so on and so on,can anybody tell me what is wrong and how to fix it. Any input would be greatly appreciated!!!!
Old Dec 29, 2007 | 03:46 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: slight problem with heater
does it cut out completely and come back on in the lower settings???...maybe a bad blower motor resistor or high resistance in the switch contact surfaces
Old Jan 2, 2008 | 04:26 PM
1mean5.0's Avatar
1mean5.0
it doesnt cut completely out it just kicks down real low then kicks back up to normal speed for afew seconds and back down.
Old Jan 2, 2008 | 04:32 PM
WhiteWindsor's Avatar
WhiteWindsor
Is it the defrost your referring to? Because that runs off the compressor.
Old Jan 2, 2008 | 04:45 PM
1mean5.0's Avatar
1mean5.0
Im not sure if its just the defrost or not , I will have to double check and get back to you
Old Jan 2, 2008 | 04:50 PM
WhiteWindsor
Since the defrost runs off the ac compressor it will kick on and off just like your ac.
Gene K
Oct 21, 2015 11:37 PM
heslekrants
Sep 23, 2015 04:02 PM
ccdguy
Sep 19, 2015 05:20 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
