glowing headers along with over heating
i discovered the other day that the number 3 header tube glows the bootom half of number 4 gets red and number 8 gets a tad hot. i also noticed that my car has been running upward near 250*. i bought a new t stat so hopefully thats my overheating problem. info on my car it has an eddy 600fm carb weind intake and the rest is all stock. hasa complete msd ignition and i belive the timing was set at 17*. so can anyone point in a direction to check. o yea im gonna run a compression check on number 3 and 8 tomorrow.
RE: glowing headers along with over heating
are you sure your timing is advanced properly/ set right....retarded timing ..excessively can cause that.....if you set it correctly or what you think is correct and you still have a stock balancer/original one it may have spun on the rubber to where when you set timing to where you think it is correct you may actually be way off
i was thinkin it may be too rich but im gonna run a compression check and make sure i have atleast good compression then prob go and have the carb adjusted for the stock parts. it was originally setup for gt40p heads and ecam
How's it idling? A little fast? Check for a vacuum leak.
I had a car that backfired through the carb and blew off a vacuum plug.
It was sucking air/vacuum leak. The idle was a little higher, that was the only symptom.
Didn't know that this happened til I got home and checked it out.
I drove it home about 5 miles and popped the hood and the header tubes were glowing, I found a rubbervacuum plug missing.
