Broken wire connector, need help
One of the connectors that gets pluged into the back of the cigarett lighter to give power is broken. Does anyone know where i could buy a new one? i know i could go to the bone yard but its cold as hell out.
http://www.rockauto.com/catalog/x,ca...parttype,10665
That's all I know of off the top of my head. A bit expensive though.
what I have done before is removed the factory one and gone down to the local parts store and bought a universal one that has universal make your own connections with crimp on connectors and rewired it with new connections = total cost of 5-7 dollars
thanks for that link, they only have one for a 95, i have a 94 but it should work right? ford didnt change anything that small in between years did they?
i think walmart sells the cig lighters.. they usually come with the correct connection and a length of wire..
so get that take the connection you need, get a crimp connector or solder it and you're good to go
yea wallmart sells them, i bought an xm radio and didnt want to see the plug sitting in the lighter all the time, so i unhooked it, and hooked up a new one and kept it under the console..
walmart sounds good il go look tomorrow, and dime i realy like that idea, im installing a gps and im going to mount in in an empty slot in mycenter counsleand make a face plat around it so it looks right, im probly gunna hide the wire in the counsel some place now. did you hide yours under the shift bezle or where?
jwog666
Dec 27, 2021 08:09 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Sep 25, 2015 06:58 PM
