valvetrain / cam help
#21
RE: valvetrain / cam help
yo, looks like you have alot of questions... tell ya what... make it easy, lol.. pm me w. a list of ur questions, since i just did this i should be able to answer all of them....
#22
so does anyone know about the valve springs for this cam? its very similar to the F-303 cam. (same lift). like what is good for: Installed Height (in). Seat Pressure at Installed Height (lbs). Open Height (in). Open Pressure (lbs) and outer/inner spring diameter
like ive been askin for a while...
mjr i was told you should kno...
#23
what I'd do since both the cams carry the same specs and require near identical open and closed pressures is use the f-cam springs cause it will insure no machining is needed and you'll need the matching retainers and locks.....the only difference between the two cams is the lobe seperation-= LSA......the cam you want and what dimebag bought will be more speed density friendly and have a better idle quality...f-cam needs to be used with mass air car
#24
#28
i wanna go single spring. and my car is an 89 so it is mass air.
should i just go w/ the f cam cuz it is cheaper then? or will i be happier w/ the comp?
#29
Go to Thumper of Orange Park and email Mike for a "drop-in" kit of springs/retainers/locks that will work with the Comp Cam. They are single with damper, and will not require any mods to the heads.
junior04
09-28-2015 10:53 AM
