timing jump
Old Oct 3, 2003 | 07:38 PM
gking's Avatar
gking
Default timing jump
my '88 GT 5.0 is jumpimg timing</P>
i set the timing at 12* , went out and made 2 stops and the car started missing so i came home and checked the timing and it had jumped to 20*. how i do not know. i checked to make sure it wasn't loose, and it was tight.when i was setting the timing i removed spout connecter before i started the car and put it back in before i killed the engine.</P>
help please</P>
greg</P>
</P>
Old Oct 3, 2003 | 07:50 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default timing jump
well if it's missing then your distributer obviously moved. Be sure it is tight enough. the only other explaination is that your balancer is bad and is slipping, but that wouldnt cause your car to run bad, just the timing marks would be off.
Old Oct 3, 2003 | 08:01 PM
gking's Avatar
gking
Default timing jump
i tried to move it but it wouldn't budge</P>
</P>
Old Oct 3, 2003 | 09:27 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default timing jump
yea but with vibration it can still move a little at a time even if you can't move it by hand. Be sure they're no oil around the distributer hold down area when you re-tighten it. Also, to be sure, you can always mark the distributer position to the hold down, but thats the only solution to your problem I can think of... assuming your distributer drive gear isn't mangled up.
Nurdyguy
Jan 20, 2025 04:38 PM
mungodrums
Oct 7, 2015 04:01 AM
StalkerGT
Sep 25, 2015 02:41 PM
Sep 8, 2015 11:50 AM
