Frustrating Temp Gauge Proplem
It all started soon after i bought the car early last year, the temp gauge does not work. first thing i did was change the temp senser, that didn't work, i then checked continuity from the sensor wire to inside the instrument cluster that looked good, i then bought a replacement temp and fuel gauge off of ebay and it still dont work, i then bought a new temp senser for $4.00 to see if the old one might have been bad, still dont work. I used my continuity tester to check the ground wire looks good i checked the "ill wire on the back of the cluster with another area that noted "ill" and that looked good. I am desperate I think i tried everything. what could it be, i dont want to change the whole instrument cluster(the miles are low and original) i would rather not have a dead gauge on my dash and i dont like the aftermarket gauge look, at this point i will try anything
Improvements made after i bought the car:
new gear
subframe connecters
cold air intake
exhaust
new gear
subframe connecters
cold air intake
exhaust
RE: Frustrating Temp Gauge Proplem
So everything is testing good. It's not a real involved circuit. You have a wire from the sender going to the cluster harness. That plugs into the cluster and makesm contact w/ the gauge thru the printed circuit board, then to ground. You sure you have checed everything correctly.
The temp sender, you are talking about the 1 wire piece correct? What year is the car, I'll see if i can get you a diagram if it's a simple one to post.
ORIGINAL: ewgoetz
94-95 have 2 temp sensors. not sure why. Which one you change?
Here's a diagram.
[IMG]local://upfiles/29779/07582E76BB0A452586879A19BA008C5B.gif[/IMG]
ORIGINAL: jjooeell
i believe i checked everthing out , it is a 95 convertable gt. it looked simple but it is driving me nuts. i would appreciate any help you got
ORIGINAL: Pearlkobra12
Rather than runnin around not knowing what the problem is...buy some nice autometer gauges
Ok, I Tried Jumping the wire off the sender unit and then turn on the ignition, Nothing...., Now what is the wire Bad? do I have to run another one all the way or is there a way to replace one part of it(not going through the firewall) where does the wire go right now i look at the harness and it seems almost impossible to distingquish were it goes,
