How mush power will a 75mm MAF handel?
RE: How mush power will a 75mm MAF handel?
From what ive seen and been told,a company under promracing.com bought some of there equipment and stillsell there meters.if not then get a lmaf or sct big air if your using there chip, and c and l meters are junk.
ORIGINAL: Mustangkiler
ORIGINAL: 5spd GT
Remember not to judge flow on the o.d. of the MAF sensor. The MAF has protrusions in it, some are big and some are small.
Pro-M rated there 80mm good up to 800 HP.
Just to put things in perspective for you.
I read the post accurately.
Calibration is very important, but the size of the MAF and protrusions there-in can be restrictions to air flow.
One 75mm MAF from Brand A will not flow the same as a 75mm MAF from Brand B.
A restriction to air flow, limits power.
More air = more power potential, right?
The company that boguht Pro M still manufactures aMAF and I bought what replaced the 80 MM unit they had, which I think is 90MM. It works fine for my setup and I have plenty of room to grow.
ORIGINAL: 88scgt
actually you are wrong stocksuspension, with no air no power
and just for the record give me a ProM any day over a C&L, however LMAF > *
