How mush power will a 75mm MAF handel?
Like it said how much power will a 75mm MAF handel before it pings? Im planing on geting a vortech SC or a Kenne Bell with in the next few months and was wundering if it will be able to handel it or will i need to get a bigger one, if it matters it is a Pro M.
Thanks
Thanks
according to the ford racing catalog here is a rough idea
MAF Sensor Approximate max hp
55 mm (Stock 88-93 Mustang) 275 hp
70 mm (Stock 94-95 Mustang) 350 hp
80 mm (Stock Ford) 425 hp
90 mm (M-12579-54) 540 hp
Remember not to judge flow on the o.d. of the MAF sensor. The MAF has protrusions in it, some are big and some are small.
Pro-M rated there 80mm good up to 800 HP.
Just to put things in perspective for you.
The calibration is all that matters, just check with pro m and find out from them because there will be a certain hp rating or air flow rating in which the meter pegs and as long as you do not go past that or have a throttle body bigger than your maf, you wont be hurting yoursetup, but i will tell you that with a kenne bell the less inlet restriction the better, and you will gain some horsepower going from a 75 to 90, how much im not sure because ive always had a 90 lmaf on my kb 94but there is a difference depending on the boost your running according to kenne bell.
ORIGINAL: militarymustang88gt
my buddy is running a c&l 73mm maf and making 550 at the wheels on his 302. like said before just depends on how it is tuned and what kind of meter and stuff.
