emissions
Old Jan 19, 2008 | 08:08 PM
nick6690's Avatar
nick6690
Default emissions
what is the mostyou can do to a 5.0 and and still pass emissions?
Old Jan 19, 2008 | 08:18 PM
tmajikman's Avatar
tmajikman
Default RE: emissions
I know for a fact that you can remove the smog pump, run 14 degrees timing, run 2 hi flow cats 2.5 inch exhaustand still pass with flying colors.
Old Jan 19, 2008 | 08:21 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
BBK ceramic equal length shorties
Mac H pipe
SLP 1 cat back w/ 3.5" polished tips
SCT custom burned multi tune chip
MSD 6al ignition system
MSD dist. cap
MSD Boost timing retard module
Crane fireball ps 91 coil
Ford Racing 9mm ignition wires
ATI Procharger 14lb boost w/ 3 core intercooler
255lph Holley in tank fuel pump
Professional Products Typhoon polished intake, 70 mm throttle body and egr plate
2 core aluminum radiator
BBK cold air intake
FMS 42# injectors
Pro M 75mm blow-thru mass air
Anderson Power Pipe
Kirban AFPR
With the converters on the car, it passes.
Old Jan 19, 2008 | 08:41 PM
tmajikman's Avatar
tmajikman
I'm Jealous Pro, one day my friend. I have not even had my car for a year yet.
Old Jan 19, 2008 | 08:46 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
That's just the crap on the motor, doesn't include everything else.
Old Jan 19, 2008 | 09:03 PM
tmajikman's Avatar
tmajikman
I am jealous of the suspension, interior and the whole car, you have one sweet notch my friend.
Old Jan 19, 2008 | 09:10 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Thanks man
Old Jan 19, 2008 | 10:17 PM
vtecwho's Avatar
vtecwho
pppssshhh, i would not want his car. who wants a cherryed 5.0 with a procharger?jk
i pass smog with perfect numbers with my mods in my sig. with 2 cats.
Old Jan 20, 2008 | 06:36 AM
cgarray17's Avatar
cgarray17
not trying to steal the tread but what does the smog pump do and if you take it off what do you gain?
Old Jan 20, 2008 | 08:04 AM
tmajikman's Avatar
tmajikman
ORIGINAL: cgarray17
You gain a few ponies, less drag on the motor, a cleaner engine bay, less weight.
It is suppose to add clean add to the exhaust before the exhaust leaves the tailpipes, better air quality supposedly.
