compression test results
Old Jan 21, 2008 | 12:51 PM
blk40th's Avatar
blk40th
Default compression test results
ok did the compression test the other night and i have 140psi in cyls 1-5, cyl 6 had 130, cyl 7 had 150, and 8 had 140 also. i put new plugs in and capped off my pcv since im running 2 breathers, and it smoothed out, but i still have a miss and its hard to start, take like 5-10 min sometimes. but the plugs helped a little with the miss, its only down low now. i put in a new fuel pump relay, new fuel pressure reg also. the plugs are still gapped at .054 im thinking i might have a bad wire somewhere.
Old Jan 21, 2008 | 03:56 PM
blk40th's Avatar
blk40th
Default RE: compression test results
any comments or help would be appreciated. thanks
Old Jan 22, 2008 | 09:41 AM
blk40th's Avatar
blk40th
is this good or bad?
Old Jan 22, 2008 | 10:00 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
compression results show a little bit of a tired motor but when it won't start for 5-10 min ..what are you missing/??? spark ?? or fuel pressure???
Old Jan 22, 2008 | 10:51 AM
Joel5.0's Avatar
Joel5.0
.... or too much fuel.....
Old Jan 22, 2008 | 11:27 AM
lxman1's Avatar
lxman1
What exactly are you working on? Plug wires, cap and rotor been changed. Have you tried holding the throttle open a little when it won't start to see if it is the IAC sticking closed (if fuel injected).
Old Jan 22, 2008 | 12:06 PM
stangman94's Avatar
stangman94
noob question! Whats your compression suppose to be at?
Old Jan 22, 2008 | 12:41 PM
blk40th's Avatar
blk40th
i feel im getting to much fuel since it smells like nothing but fuel. but anyways i turned the dist. a little to the passenger side and it started up no prob. but it still has a horrible missfire.
TCStangerv6
Oct 11, 2015 05:57 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
