harmonic balancer on
Old Oct 6, 2003 | 02:38 AM
quantum555's Avatar
quantum555
Default harmonic balancer on
i was talkin with some guys and one mentions that the crankpulley has a harmonic balancer that is not replaced with aftermarket pulleys and could mess up the motor. i did not really catch the whole story but i figured i would run this by an audience for input. they may have been talking about a supra...i was tired<IMG src=smileys/smiley5.gif border="0">
Old Oct 6, 2003 | 10:17 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
bs
Old Oct 6, 2003 | 12:24 PM
SilverGTV8's Avatar
SilverGTV8
4.6 motors need not to worry a good kit has the dampner (I.E. Steeda). Aslong as rotating mass in balanced no balancer change is needed
Old Oct 11, 2003 | 05:20 PM
4HoleKraut's Avatar
4HoleKraut
Originally Posted by mdvaldosta
bs
</P>
This is not necessarily correct. Probably would not be as likely to create problems on a 5.0 as say a 2.3SVO.On a 4 cylinder, using a non dampered pulley could create excess vibration in the crank which would ordinarily be absorbed by the damperwhich could in turn cause excess wear in the main bearings. Due to a more frequent power (combustion) stroke in an 8 cylinder, the wear on the main bearings would likely be decreased if not totally diminished (compared to a 4 cyl.) by the lack of a damper. I have notpersonally experiencedthis but I have torn down an engine and this was the result from an undamped pulley. Again- this was a 4cyl, not an 8 cyl.</P><edited><editID>4HoleKraut</editID><editDate>37905.6524189815</editDate></edited>
Old Oct 11, 2003 | 06:03 PM
vshayes's Avatar
vshayes
I ♥ Acer
I guess I wasn't paying attention as well as I should have, I understood what he said as saying that if you don't replace your balancer when you put aftermarket pulleys you could mess up your motor. I have yet to see a crank pulley that doubled as a harmonic balancer on a 5.0. As far as other engines, if the balancer is part of the crank pully, well then that kit would come with the balancer.</P>
</P>
Old Oct 11, 2003 | 06:20 PM
vshayes's Avatar
vshayes
I ♥ Acer
That was Joe (mdvaldosta) He forgot to change IDs on the CPU
mtgldr
Feb 3, 2024 09:00 PM
jessicarabbit
Sep 25, 2015 12:41 PM
LivingInThePast
Sep 16, 2015 12:20 PM
Sep 8, 2015 11:50 AM
Sep 1, 2015 08:16 PM
