AOD or C4?
ORIGINAL: Mustangkiler
The converter stall speed and gear in the back should be matched to whatever cam you plan on using.
well ive been looking and it looks like im gonna stick with an AOD i saw a rebuild kit on ford-aod.com for around 900 bucks which is half the price of a brand new AOD and do you guys think it will be a good idea if i grab an aod out of the junk yard and use the rebuild kit on that? also do you think itll be a good idea to replace the valve body?
ORIGINAL: vvelez5
ORIGINAL: vvelez5
I know i was told dont ask on this site so my question is who should i ask to get the right torque converter?
If you get a used AOD.....get one from a crown vic or mercury or something NOT a mustang. I dont know what you were looking at for 900 as a rebuild kit but like i said earlier. TCI makes a rebuild kit that includes all clutches and an over-drive band and a shift kit for 250!!! that should be all you need if you get a tranny from something that was most likely granny driven. replacing all the clutches and OD band should be all you need to do. and like me and mjr said usually no need to replace the valve body.
my bad hillbilly i skipt your thread i didnt need to ask all that stuff if i read your thread. Why should i get an aod out of a mercury or crown vic? (curious) and the one rebuild kit for 900 bucks has the following you guys tell me if i should just go with the tci i really dont know this is from www.ford-aod.com the dominator jr. rebuild kit
[ul][*]alto clutches[*] high performance Superior Posi Shift Pac[*] eight count Alto Red Eagledirect clutch Power Pack[*] Carbon Fiber overdrive band[*] high performance Superior A+ overdrive servo[*] filter[*] heavy duty 2500 RPM stall converter (#14)[*] hard lock-up shaft[*] spiral snap ring[/ul]It seems like thats if i wanna make it to a race car but it is able to hold up to 500hp with that kit.
the tci comes with
* Gasket and seal kit
* High-quality clutches
* Steels
* Forward bands
* Adjustable modulator
* High-volume filter
* Drain plug kit
* Trans-Scat valve body modifications
but it doesnt say how much power its good for i like the tci better cuz its cheaper but would i still have to buy a converter? and if i do i noticed the pricing is about the same with the one from ford-aod.com comes with a few more parts but if i dont need it then i dont want to spend the money
the tci comes with
* Steels
* Forward bands
* Drain plug kit
ORIGINAL: vvelez5
http://www.badshoeproductions.com/products.html#aod
