fuel pump help
Old Jan 29, 2008 | 04:55 PM
benz5800's Avatar
benz5800
Default fuel pump help
hey my stock fuel pump just **** the bed and i need a replacement. i didnt know if it would be like overkill and effect other things if i out in a higher flowing pump than what was stock.
Old Jan 29, 2008 | 05:01 PM
white93pony's Avatar
white93pony
Default RE: fuel pump help
i would buy either a 190 or 255, but to answer your question no it wont affect anything it will just give you the xtra fuel when needed.
Old Jan 29, 2008 | 05:06 PM
WhiteWindsor's Avatar
WhiteWindsor
What he said. Your regulator will determine howmuch the fuel flows. Go with a walbro 255 then you will have the fuel pressure when you build your engine.
Old Jan 29, 2008 | 06:01 PM
benz5800's Avatar
benz5800
thanks brothers i appreciate it
Old Jan 29, 2008 | 06:10 PM
86 5.0L's Avatar
86 5.0L
http://www.jdsperformance.com/index....amp;inmake=136
here you go, cheapest place to get the best pump
when I replaced mine, the oem pump was a walbro too, i was surprised at that
Old Jan 30, 2008 | 02:08 AM
silentvoice19's Avatar
silentvoice19
dont you have to get a regulator if you get a 255?
Old Jan 30, 2008 | 02:33 AM
86 5.0L's Avatar
86 5.0L
no, the engine will only use what it needs, the 255lph rating is what it CAN supply, not what it WILL supply
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
Sixx
Oct 5, 2015 07:36 PM
mrappe
Sep 26, 2015 10:16 AM
