4 cylinder springs
RE: 4 cylinder springs
AFTER my 2.3 to 5.0 conversion in my 92 I had the 4 cyl springs still in.....the stance looked good and road quite well don't ask me why but I swapped 'em out for 5.0 ones and I don't like the stance as well now..oh well ...live and learn!!!
If you are gonna take it to the track alot, i suppose they would be good. As said above, they have a much softer spring rate and provide much better weight transfer. But you probably wont have very good handling characteristics. (ie body roll) If you mainly drive on the street and see minimal track use, I would just use a stock V-8 spring and maybe a slightly softer shock or if you have the money, get adjustables.
****... i have em up front, and no sway bar... AND loose *** struts... and skinnies, lmao... and i DD my ****... its not that bad on ur handling, yes its worse, but its easy to deal with and its not a restriction... and it helps ALOT w. weight transfer
ORIGINAL: dimebag
yea i ahve strange 10 ways set at the loosest setting all the time and banger springs, the quality isnt that bad, but no more doughnuts for me
