New motorcrafte distributor and now car wont start!!!
Old 02-14-2008, 11:46 PM
88mustang50
88mustang50's Avatar
Default New motorcrafte distributor and now car wont start!!!
i just bought a brand new distributor and now the car will not turn on!
the starter turns the motor but it just wont actually start running.
it will just backfire every once in awhile.
new wires and plugs aswell but those worked with old dizzy.
old one was steel gear and so is new one. (if that matters...???)
88mustang50 is offline
Old 02-15-2008, 12:00 AM
Tberg725
Tberg725's Avatar
Default RE: New motorcrafte distributor and now car wont start!!!
Double check the firing order.
Tberg725 is offline
Old 02-15-2008, 12:24 AM
Tberg725
Tberg725's Avatar
Tberg725 is offline
Old 02-15-2008, 12:31 AM
88mustang50
all the plugs and wires are in the right place.
Old 02-15-2008, 01:16 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
but is the rotor button inside the dizzy?
rmodel65 is offline
Old 02-15-2008, 01:39 AM
88mustang50
ORIGINAL: rmodel65
how could i check that???
the distributor rotor button in the dizzy i think was facing a different way but dosent it spin anyway?
Old 02-15-2008, 02:26 AM
ewgoetz
ewgoetz's Avatar
Means ur timing is wrong. Best bet is to get a manual and follow the sets in it. If you checked where it was at when you pulled out the old one you could of gotten away with putting it in the same way the old one was facing. You will have to take the dist out and readjust which way the rotor is facing to the correct direction. You will have to bring the motor to tdc on the first cylinder, and make sure the rotor is facing he #1 wire.
ewgoetz is offline
Old 02-15-2008, 06:12 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: 88mustang50
ORIGINAL: rmodel65
It can't just go in any ole way. Read this link
https://mustangforums.com/m_3264510/tm.htm
PRO50SC is offline
Old 02-15-2008, 06:24 AM
AdderMk2
Banned
AdderMk2's Avatar
[sm=icon_rtfm.gif]
AdderMk2 is offline
Old 02-15-2008, 07:20 AM
joeymustang
joeymustang's Avatar
ORIGINAL: Tberg725
using the circle diagram of the plugs you can find it....just put the dizzy cap on with the cables, mark on the dizzy where the #1 cable is sitting, take the cap off, and try to line up as best as you can the rotor with that line. After it turns on, check your timing
joeymustang is offline
Quick Reply: New motorcrafte distributor and now car wont start!!!
