Problem need help!!
ok i put car back together and i need help. my headlights,foglights,and power mirriors work nothing else works. i think im not getting power to my solenoid. but im not sure its brand new so it should be good. but it wont turn over or anything.
I just ran into this with my 91. I had no power to the yellow power wire on the ignition switch. That power runs from the soleniod, to the fuse box and then to the Ignition. Use a test light at the fuse box and see if you are getting power there. Make sure that you connected all of the wires to the battery wire on the Soleniod also. If it is around the same year as mine I can email you the wiring diagrams.
Seanam
Oct 4, 2015 10:15 AM
stangin1996gt
Sep 21, 2015 11:01 AM
