88 5.0 KIcks!
RE: 88 5.0 KIcks!
ORIGINAL: 50Stocker
clean the mass air sensor
RE: 88 5.0 KIcks!
ok yea cause ithe first thing i did when i bought the car no matter what was buy everything to tune the car up including the fuel filter its what i always do no matter what car it is. but yea thanx for the help ill try that n let u know
RE: 88 5.0 KIcks!
yeah first check the fp, not just while idling, need to check it under load
if the fp doesn't flutter a bunch (34-42 psi range at wot) then go to electronics.
check timing, plug wires, plug gap (gap it at .040" and see if it helps...if yes..it is ignition/coil) and just use copper plugs, no platinums or anything else stupid
this is assuming you have already replaced the fuel filter which should just be done anyways.
RE: 88 5.0 KIcks!
ok so i was messin with it right now and as i had the hood open and was throttling it from the linkage by the motor if u throttle it and hold it while it bogs down it'll pop and from what it sounds like is that its coming from the throttle body. could it have somethin to do with the MAF?
