Check engine light and beeping
when i start the car the CEL will come on and then 5 beeps 5 times there is a pause in between every 5 beeps. does this sequence mean anything?? ive about had it with this damn car, i almost wish it was a bomb beeping about to blow up so it would take away all the headaces this car has caused me. Please help.
RE: Check engine light and beeping
CEL on and beeping are not related.... LOL...... what year is your Mustang?....does it have the airbag system?...... for the CEL on problem though, you need to run the DIY KOEO/KOER/Cylinder Balance Self-Test
the beeping is probably the air bag system...when I converted my 92 from 2.3 to 5.0 and made it carb the air bag light would flash so I removed the bulb thinking that'd be it.. but once I did that the module beeps on start up indicating a fault....well duh!!! it's not hooked up anymore......also if the bulb for the air bag system is burnt out that may be the cause.. but every 1/2 hour or so it'll sound off..I've just been to lazy to ever un plug the module
i didnt know, though that might be a diagnostic thing. anyway yes alot of bulbs are blown. how can i deactivate this damned beeping, unplugging the module, where is this located??? thanks for responses guys
oh yea the car is 94 gt 5 speed
is this the noise you hear??
http://s242.photobucket.com/albums/ff63/mjr46/?action=view¤t=airbag.flv
ORIGINAL: gtpcoupe
and for that test i dont have a volt guage and that process seems complicated as hell or is it just me?
