Off road H-pipe
Off road H-pipe
i just got my new hpipe and want to put it on and my dad says that i need to have it on a lift to get to the header bolts to undo the old hpipe. how would i get to the header bolts for the hpipe without needing a lift. i think i just need to have jack stands to do it but my dad thinks i need a lift. thanks [/align]
RE: Off road H-pipe
easiest way (other than a lift) is the front on ramps, and the rears on jackstands, as hi as you can get it.
very very easy , but expect to have trouble w/ the header to h-pipe bolts.....they sometimes seem to be welded and take hours to get off. air tools help...but not much room to work with.
if you do get them off w/out cutting...do yourself a favor and use some anti-seize on them for the reinstall. also...the the o2's might get broken on the way out too, so expect to replace them.
RE: Off road H-pipe
ha... Ive done it parked halfway in the street half in the driveway, only able to fit one arm underneath at a time... Its not that bad at all. If you have access to a lift, though, use it because not only will it be easier, but you can check out other things too
RE: Off road H-pipe
ORIGINAL: nitrous_bob
