new heads!!
RE: new heads!!
Edelbrock heads are not worth the cost IMO, I say this from experience. They are a mass produced head that are designed to be used with mid range cams. If you are looking to use a cam with high lift and duration numbers the springs are no good. The valves, retainers, and locks are basically just better than stock. The spring install heights are not measured for assembly leaving as much as .050 varience. Some do not come with harded spring cups (lower retainer) and only come with a hardend shim.
I had a set of 5.0's that had approx. 400 miles and 6 passes when I discovered the valves tips were pitting and burring, This was with a "B" cam. With some research, it was found that the valves were mass produced junk. I also worked with a set of RPM's and found no springs cups (lower retainers) and the factory install heights varied. The valves were better than the 5.0's, but they were pretty soft allowing the locks to cause large burrs where the lock rested (heads had 200 miles and 25 passes and a midrange FT cam) making it necessary to file the stems to remove the valves. I am still using the RPM's but I replaced the entire valve train. When it was all said and done, I could have had a much better head to start with.
There are much better heads out there, Trick Flow, Canfield, AFR.
RE: new heads!!
I have Edelbrocks on my '93 LX. BUT, they were instlled when the build was done, in the Fall of 2000. That's seven years ago. Things may have changed a bunch in that length of time. I know mine are still just fine.
RE: new heads!!
ORIGINAL: moterhead
RE: new heads!!
im probably going trick flow being that they come with everything minus the rockers..but i wont be running a monster lift cam probably somehting int he 520 530 range at most i wanna get a custom cam
RE: new heads!!
ORIGINAL: PJC Racing
And how do you know this? Have youdisassemble, inspected, and measured them ever? I bet you won't be saying they are just fine when and if you do.
ORIGINAL: moterhead
RE: new heads!!
ORIGINAL: 89mustangfive0
