94-95 AODE
Well i finally had a chance to look at my stang again it was breaking up after it warmed up and had no throttle response. IF you watch the 02's they would drop to 0 and the vehicle would act up in all gears and park/neutral. If anyone else has a similar concern please be sure to check the electronic pressure control sol. With the aode if this circuit goes down the engine will go into a torque management mode and the vehicle will not make any power at all. Once i backed pin 38 out of the pcm it ran fine. Just a bit of info btw that is the only circuit that will cause the pcm to randomly kill cylinders due to failsafe. Btw it took over an hour to set the code p624
