clutch or transmission problem please help
Old Apr 6, 2005 | 12:59 AM
86stanggt's Avatar
86stanggt
Default clutch or transmission problem please help
well i brought a 86 gt last summer it had a disassembuled t-5 transmission the gears were rounded off so i got it rebuilt when i brought the car they said it had a new clutch put in it and it sat outside for about a year with just the bellhousing on and now that i put the transmission back in and have started it. i have it running and i can't put it in gear but if i put in gear and then start it then it will move but can't won't shift to second. and i have bought the adjustable clutch cable from bbk i don't know what to do now
Please help me?!
Old Apr 6, 2005 | 01:04 AM
primetime5.0's Avatar
primetime5.0
Default RE: clutch or transmission problem please help
the clutch could just not be grabbing all the way
Old Apr 6, 2005 | 01:06 AM
Pure5.0's Avatar
Pure5.0
Bad clutch fork?
Old Apr 6, 2005 | 01:14 AM
birdman076's Avatar
birdman076
Clutch is probably frozen to the flywheel with rust from sitting outside for a year with no tranny mounted to protect it from the elements. I have seen that happen in only a few weeks here in Florida, the humidity is killer.
Old Apr 7, 2005 | 12:28 PM
86stanggt's Avatar
86stanggt
so what should i do about this problem
Old Apr 7, 2005 | 04:12 PM
Dan89lx's Avatar
Dan89lx
adjust the cable down at the clutch fork. tighten the nut on the cable until the clutch fork barely has some play in it. I had a similar problem and thats what finally fixed it. Good Luck
Old Apr 7, 2005 | 06:08 PM
88PatrolCar's Avatar
88PatrolCar
Try pulling up on the clutch pedal, if it was out of adjustment you will hear a loud clunk. But it is most likely frozen up in their from rust.
Old Apr 7, 2005 | 06:15 PM
birdman076's Avatar
birdman076
If its frozen to the flywheel you will have to remove the bell housing, and unbolt the pressure plate. Then soak the clutch disc with PB blaster or some other lubricant that is good at eating rust. You may end up having to pry the disc off the flywheel, then unbolt the flywheel take it to a machine shop to check for tolerances and see if it can be resurfaced. By a new clutch disc, pressure plate, throw out bearing, and possibly clutck fork, reassemble and drive it till the wheels fall off.
Pyrate Dave
Sep 10, 2015 07:30 PM
Roush05
Sep 10, 2015 12:23 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
