Quick fuel pressure question
Old Apr 12, 2005 | 05:48 PM
  #21
Green5pt0's Avatar
Green5pt0
Default RE: Quick fuel pressure question
No, how would I do that?
Old Apr 12, 2005 | 05:49 PM
  #22
stanglx2002's Avatar
stanglx2002
i think you can take it too autozone and they can check it for you
Old Apr 13, 2005 | 12:43 AM
  #23
Green5pt0's Avatar
Green5pt0
I took my ICM in to have it checked and it failed so I bought a new one. If i have time tomorrow afternoon im going to put the distributor back in. Until then I'll have my fingers crossed! Ill let everyone know how it goes.
-Green5pt0
Old Apr 13, 2005 | 03:13 PM
  #24
Green5pt0's Avatar
Green5pt0
I just installed the distributor with the new ignition control module and checked the timing to make sure it was still at 16 degrees. It was so I went for a drive. The same symptoms are still happening. So, now I'm out of ideas, how about you guys?
-Green5pt0
Old Apr 13, 2005 | 06:33 PM
  #25
Tims 88GT's Avatar
Tims 88GT
did u put the gasket on the fuel pressure regulator? i know that a dumb question but its easy to forget, i ran 42ps with the vacume off and 14* and it ran great, also the more retarted your timing the more lowend you have and the more advanced the more high end you have, try settin it to 10, if that dose not help set it to 18 or so, go from one extreme to the other, if one runs better then the other that will tell you if you have to much or not anugh fuel. also you can try resettin the computer
Old Apr 13, 2005 | 07:11 PM
  #26
91LXstanger's Avatar
91LXstanger
Backfiring is definatley a timing issue. Set it to 12*. That should be fine. Theres no reason why that shouldnt be okay. Then set the WOT pressure @38-41psi. I had some backfiring on my other ride when i was messing with the timing, and i had 3 1/2 inch talis. Imagine how loud that was!.lol. Hows ur fuel pump? stock?. Maybe the pump is bad.
Old Apr 13, 2005 | 07:48 PM
  #27
90Mustangfan's Avatar
90Mustangfan
I ♥ Acer
the stocker fuel pump is set to flow enough for exactly 225hp, any more and your not getting the pump you need. just thought Id add that info
Old Apr 14, 2005 | 01:15 AM
  #28
Green5pt0's Avatar
Green5pt0
Well what I dont understand is that the timing was set at 18 all last summer and the car ran flawlessly. Over the winter I put on the fuel pressure regulator and it is sealed up right, and I changed the spark plugs. That's when the problem occured. I never touched the distributor over the winter... Any ideas?
Old Apr 14, 2005 | 07:22 AM
  #29
92BOOSTED's Avatar
92BOOSTED
Do you still have the split fire plugs in it?
Did you have this problem before you installed these plugs? Try putting some stock recommended plugs in it,basically starting over set the fpr @ 42lb and your timing at 14 deg. with spout removed.
The reason im talking about the plugs is maybe your engine does'nt like these or you got the wrong heat setting.( plugs may be too cold or hot ).
Your car should run great at 42lbs of fuel with timing at 14-16 degrees.
Rye
Old Apr 14, 2005 | 11:54 AM
  #30
stanglx2002
i would recommend you to get autolite #25 they are the recommended plug for our car and thats wht i run in my stroker
