afr 185's on a stock bottom end?
ORIGINAL: FASTBLACK
I've got a custom nitrous grind but no nitrous[:@]. I'm just surprised he could make that cam work in a stock 302 block.
I don't have a custom grind ....BUT i GOTS THE NOS!!!!
ORIGINAL: OnyxCobra
are you talking before or after boost numbers?
And toaode lol i know to be careful, i clayed the cylinder before torquing down the heads to make sure i had enought clearance and anyone running big valves/big cams should do the same
ORIGINAL: mjr46
ORIGINAL: FASTBLACK
ORIGINAL: 1991LX5.0
After, i had the blower on the basicly stock motor at 6lb then i put the H/C/I on and upped the boost and took it to get tuned.
ORIGINAL: OnyxCobra
The 185's would have made around the same power but theres no way i would have made 450rwhp on only 8lbs of boost with 165's. It didnt make sense at all to go with 165's on my car. Your going to make more power with the 185's/canfield 195's plus if i ever want to upgrade to a dart block 347 (which i plan on doing)you can still use the same heads with a little port work, i would never have been able to use the 165's
Dragonus18
Sep 9, 2015 01:21 AM
