few AOD questions
RE: few AOD questions
ORIGINAL: westcoastpj but when i get the transgo shift kit,and get the lentech valve body,are those two able to work together?
Or check out the Baumann kit, everyone that has had it loves it (including me)! I have not one complaint about it.
www.becontrols.com
www.becontrols.com
ORIGINAL: PJC Racing
The Lentech Valve Body will eliminate the shift kit. Don't waiste your money, get the valve body and be done with it.
westcoastpj, as far as the 3rd to OD when driving on the street,you wont know the difference with the epoxy mod, justput it in OD, and it will drive as normal. As far as the converter, yesit will require more rpms to get the car rolling. It's hard to say how much. A 3000 rpm converter will "flash" at a lower rpm,plus vehicle weight and gear ratio also affectwhen the converter will flash.
http://www.becontrols.com/products/products.htm
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
