holley whistle
holley whistle
i put the new holley systamax on. got the car started up big improvement. but when i rev up around 4000-5000 it makes this crazy whistleing sound from inside the manifold area.so the first thing i checked was all my vacum lines they are in great shape hooked up right. i checked all my manifold bolts they were good. i cant find were its comeing from the car idels fine. anyone know?
RE: holley whistle
heres vid of it only cell phone vid poor quality and no its not the belt
http://www.youtube.com/watch?v=sZgHfTpTyQw
RE: holley whistle
You didn't notice the turbo that's on your car??
haha, just messin. I've heard of aftermarket TB's whistling sometimes, I think it's the BBKs. maybe there's a casting flaw inside the manifold or something?
RE: holley whistle
Stock tb and egr but man did i clean them out.. the egr was caked in carbon dust same with the tb. my friend thinks its the manifold. He has a trickflow on his mustang and around a certian RPM he said it sounds like its burping. and no to the turbo thats my next project for the 408 stroker
RE: holley whistle
sorry nno help on the holley but i have something similiar on my 306 with a edelbrock rpm 2 it is a whistle like right off idle and when u rev it up and it goes away around 3000
i thought it was my tb as my previous motor had a 65 mm bbk and it whistled not like this or like yours it sounds like it is the intake as you are describing too i thought it was my baffle ove rthe pcv hole but no. mine sounds like **** too wtf[8D]
RE: holley whistle
ORIGINAL: Boosted5.slow
What happens sometimes with the aftermarket TB and intakes you will get sharp edges where ports are drilled. For examplea sharp edge on the inside of a intake where a vacuum port is located. If you take a file to that sharp edge the noise will go away.
RE: holley whistle
take the belt off see if it still does it... my car used to make a loud whistle noise around 4000rpm all the way to 5500 rpms when i shifted and it was the A/C compressed pulley scraping on somthing
