Help!!!!
Old Mar 17, 2008 | 12:04 PM
v8 all the way!'s Avatar
v8 all the way!
Default Help!!!!
Okay so my car wont start. It will just click once and then stop. Its not the battery cause i got theat tested but my battery terminals are all messed up and i need new ones. I think this is my issue and im going to get new wires and all that for the battery. Is wiring it up hard and is there anything else that this could be? thanks
Old Mar 17, 2008 | 12:17 PM
89 5.0 Mustang's Avatar
89 5.0 Mustang
Default RE: Help!!!!
like i said befor its probably the hack job the guy befor u did and actually its not hard i dont believe
Old Mar 17, 2008 | 12:19 PM
v8 all the way!
its pretty easy. It looks like a pain though!!!!
Old Mar 17, 2008 | 05:54 PM
TRexGAWD's Avatar
TRexGAWD
Replacing battery terminals and wires is a cake job. While you're at it make yourself a grounding kit with some 8-10 gauge wire. Try to make at least 4 good contact points on a clean surface of the frame. I suggest using a wire brush to scrape off paint to expose clean bare metal. Most people think it's an import thing but any car could benefit from it and you may get a better spark to your plugs. Kits run about $50 but you can make your own for much cheaper.
Old Mar 17, 2008 | 07:44 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
fix the cables and go from there..could have a bad starter selonoid and or starter
