Heater core install question
I have an 85 GT and am about to install a new heater core. My question is a friend of mine has a 79 mustang and says that it should only take me an hour tops to install a new core. He claims that there is a difference in the years and that mine falls on the old design and doesn't require me to remove the whole dash to change mine. Has anyone had any luck on a 85 or is my friend on crack..
Jim
Jim
RE: Heater core install question
There are some good directions out there that show step-by-step.....not sure now because I am at work...
Try the search feature.....you will definitely find some good links
ORIGINAL: CantStopTheFox...
In early Foxs the heater core is easy to get at, by just removing the glovebox, undoing the hoses, and the core sits on top of the register in a plastic shell.
On later model Foxs you have to remove the whole register, and dashboard.
I think the change came about in 1987 or 1988. Consult a Hayes or Chilton...
I had to do it on my 89 and had to remove the entire register. In my previous Stang, a 1980, it sat on top of the register with a couple of screws holding it in a plastic shell.
G
G
Calizic
08-28-2015 01:46 PM
DrunknRuckus
08-23-2015 10:05 AM
