cobra rocker arm ?
RE: cobra rocker arm ?
Improper rocker geometry, excess valve train noise, excess wear. They don't always need shims, but you have to verify the roller pattern on the valve stem to see if/where the shimms are needed.
ORIGINAL: PJC Racing
i've got a loss of power from start til about 3 grand and it goes away if i advance timing to like 30* something is screwed up and i have no idea what it is so i'm just trying to go over the things i wasn't sure about when i was putting this motor together i didn'tput the shims in cuz i was missing two of them but i didn't know if it would cause any problems
Lack of shims will not cause this much IMO. I would start to look at the cam and or distributor. What cam, how was it installed (retarded, dot-to-dot, advanced), and was it degreed? What kind of distributor (TFI)? Are you sure its stabbed properly.
