rattle?
rattle?
ok i put some hotchkis caster camber plates on my 95 and everytime i hit a bump it rattles at the top. i checked and everything is installed correctly and every bolt is tight. has anyone else had this prob?
RE: rattle?
When I installed my plates, the bolt that connects to the end of the strut loosened up......
Everytime I hit a bump, it would bang and rattle......tightened it up, no problems.....
I have the Maximum Motorsports....they came with small cylinder-like washers to slip over the strut to reduce movement....did yours have something like that?
RE: rattle?
yea i had to put the spacer you speak of with 3 washers a rubber grommit then it went through the plate another grommit a washer then the nut. i checked tightened everything drove it and its still rattles.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
movielover40
09-15-2015 10:37 AM
