TICK TICK TICK TICK HELP!!!
#21
RE: TICK TICK TICK TICK HELP!!!
i changed the oil man and the noise persisted the guy at autozone said top put thicker oil in it it would be good...i had no problems before this .....did i make the oil pump stop you think?
#22
You very well could have.
So how did it go??
You had a noise with low oil pressure at idle
The yahoo at auto zone told you to put in dyno syrup
The noise got worse/stayed the same and now your oil pressure is nothing all the time after changing again to straight10w30?
If this is correct - distributor and pan must come off.
So how did it go??
#23
kind of i had a slight tick because my oil was a little low...
yahoo dip stain told me to put in a thicker oil 20 w 50.....
and stp (blue bottle)
drove it sounded fine for about an hour drove it .....
started it back up to run to the corner when ... by the time i pulled up to blockbuster the noise had come into affect.....
and its F'N LOUD man i immediatley drove home (less than a mile)
havent started it since
why the distributor?? Cuz of the shaft?
#24
someone told me to put in some seafoam and thatll clean out anything i have that may be clogged (pump screen etc) but im scared of poutting **** in my engine lol .... comments
#25
There is no Gatekeeper. Only Zuel.
There is no mechanic in a can. Only ignorant canhead mechanics.
You wouldn't put a Band-aid on a gunshot wount and I wouldn't put in thicker oil to get higher oil pressure. Thats like putting sawdust in a trans that slips.
From now on: Motocraft 10w30 straight with a good filter changed every three months OR three thousand. No ifs ands or buts about it.
#26
If your oil pump screen is clogged you should replace the pump anyways because the pump needs lubricant. Check your pushrods because you just have to loosen up the rockers enough to pull the rods out. Roll each rod on an even surface, if the pushrod is good it will roll straight and lay perfectly along the surface. If the pushrods are bad, replace them. I would still check your oil pump and make sure it is not clogged regardless if it is the pushrods or not.
#28
Prepare yourself to start tearing this motor back apart. When your low on oil and start hearing lifter noises, usually, you destroyed the roller bearing on the lifter its self, and scratch the main and rod bearings resulting in low oil pressure.
Replace the bad lifter for the noise.
If little to no oil pressure , then inspect the main and rod bearings, if you found a bad lifter, inspect the camshaft lobe it rest on.
If the crank was not turned to remove the scorns, oil pressure remains low.
#29
ok WTF ive changed the oil pump ...the shaft...the screen....the exhaust gaskets...added collectors.... changed oil twice!! replaced oil pump still ticking...now the oil pump was seized for sure shaft was snapped in two and looked like a drill bit......how do i tighten down the rocker arms what would i torque them down to......and how do i tell if they are roller rockers? Now the ticking is fro mthe top part of the engine it sounds kind of like its winding down when i shift gears ..like a floating sound??>>!?!?!>!?!>!?
HELP!!
HELP!!
#30
Didn't read ALL the replies here but Is the car an auto or stick? If stick put light pressure on the clutch pedal and see if it goes away. The throwout bearing is NOTORIOUS for mimicing valvetrain noise.
