edelbrock heads HELP
i need to know if these are machined for the loc wire gasket....if so can i use a regualr or do i need the loc wire...thanks
http://i247.photobucket.com/albums/g...e/DSCF0639.jpg
RE: edelbrock heads HELP
looks like just where the compression sealing ring made a imprintation..run yuor finger across it..it'll be an obvious groove cut out and if so you need the loc-wire gasket for it to seal properly
if its raised, that might be the loc wired ones, i havent had a set of those before, my reg. eddy's had a light impression from the gasket, but not raised above the head suface enough to form a "raised edge".
noo i just bought the heads and i just wanted to throw them on...but of course nothing works out right.. heres a pic of what the groove looks like idk if its common or what it is http://i247.photobucket.com/albums/g...e/DSCF0639.jpg
