Are my cats bad? Any advice?
Old 03-21-2008, 10:17 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Are my cats bad? Any advice?
if car is overheating at idle check to see if elec fan comes on...most likely it's a cooling fan issue
mjr46 is offline
Old 03-24-2008, 02:01 PM
kennebellgt
kennebellgt's Avatar
inside the radiator looks good, and my fan seems to be just fine, and YES i bought the car with two and a quarter inch piping and its a xipie with stock cats.
kennebellgt is offline
Old 03-30-2008, 07:22 PM
89stang0890
89stang0890's Avatar
replace the cats
89stang0890 is offline
Old 04-01-2008, 10:15 AM
xfasteddiex
xfasteddiex's Avatar
to check cats put it on a lift with a welding tip on torch blow a small hole 1/8-1/4 "inpipe infront& rear of cats startcar & check pressurs in front & behind catsit shouls be nearly equil mabe a bit more in front if a lot more in front replace them if not weld up holes i worked at amufflershop for a few years & ive done many this way
xfasteddiex is offline
Old 04-01-2008, 12:31 PM
badtzmaru
badtzmaru's Avatar
A couple of questions: your mods that are on your list, did you just do them not too long ago? did it happen (overheating) after mods? the reason I am asking is because when i started modding my 94GT it started overheating while at stop or reduced speeds but as soon as I step on the gas and started moving it started to cool down, i checked radiator, fan and no problems so what i did to resolve this was to change the thermostat (lower temp) and so far no problems.
Anyway, good luck.
badtzmaru is offline
Old 04-01-2008, 04:05 PM
cody91mustanglx
cody91mustanglx's Avatar
the cats are worthless, unless u live in california, but if ya dont, u need to remove them and go with a off road x pipe
cody91mustanglx is offline
mtgldr
02-03-2024 09:00 PM
ak98
02-18-2023 08:36 AM
Pyrate Dave
09-10-2015 07:30 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Are my cats bad? Any advice?
