MAF concern
MAF concern
Ok i have 19# injectors and want to install 24# due to engine mods. I knaw tha a 97 mark8 4.6dohc uses a maf for 24# injectors can i use this maf? or can someone suggest another maf that can be used other than a aftermarket?
Thanks in advance
Thanks in advance
RE: MAF concern
I believe the calibration is in the ecm on the Mark VIII. The sample tube sizes are different in the C&L units to calibrate for injector size. I don't think the Mark VIII unit will help you.
RE: MAF concern
NO!!
The MAF calibration is dependant on the ecu.
Unless you use a Cobra ecu, you can't run a Cobra MAF.
If you are running boost, then go 30's... at least.
Don't waste your time dinking around with a Ford MAF meter. (unless you have a custome tune/programmable chip in your future?)
jason
jason
