cams...
RE: cams...
imho, those dated 15yr old alphabet cams are old technology, you'll have much better results with a dual pattern cam... tfs stage 1, crane 2031, anderson n- / b- cams, comp 274, crower 15511.....etc, but also if you have a matching/complementing setup, a befxz cam can do the damn thing....just dont pay more than 70~80 bucks for one.....
RE: cams...
Oh I meant fuel injected by FI, well I guess I found my first mod! lol I need to get tires first though... I need 400$... Can I purchase the E cam from ford racing? Who has the best prices?
RE: cams...
get a trick flow stage 1 cam. (.499/.510). i would rather have this than the Ecam cause it has more lift and split duration. it has more exhaust lift and duration- that what fords need.. Summit sells the trick flow cam for like $140. By the way, I have an Ecam in my car.
RE: cams...
How is my exhaust hurting me? And where would you suggest that I start? I don't have a ton of money to be dumping into heads or nothin. Oh and one more thing about the trick flow cam... I've heard that you don't want to go over .500 lift on stock heads
