CAR HESITATES
CAR HESITATES
If i am idling and i go to rev the car it doesnt rev up itll take me like three times to get to be a crisp response. When i pin it itll take a second to kick in and then finally go. I changed Cap, rotor, plugs, wires, fuel filter, and just added some fuel injector cleaner and neither seem to have done it. What else would would you guys suggest?
RE: CAR HESITATES
are you talking about backing the idle screw all the way????or just with the butterfly closed??
ORIGINAL: roundman
have you adjusted the TPS output voltage to .98 volts with the throttle closed???
this will make the computer respond better to any movement of the gas pedal.
RE: CAR HESITATES
I have the same exact problem man! Also when I nail the gas in gear, it like boggs its way up to 4k rpms or so and occasionaly pops really loud, sorta like a backfire from the engine compartment. After doing it 3 or 4 times though, its fine. I also replaced the fuel filter behind the tank, cap, wires, rotor, plugs, ECT sensor, and nothing. The wires helped a little considering one of my last ones was blown wide open. Still not much of a diff though.
RE: CAR HESITATES
i'm thinking your car as well as most 5.0's on here is having a "loading up" problem??...if i drive mine normal it will have alittle hesitation prob...but it's very slight.....if i take the ol'girl out and open her up she's fine for a couple of day's...then again i think it's time
for a re-tune.
for a re-tune.
